Huffman32
hey guys i have a 1990 bronco 2 and im trying to make more power out of the 2.9 motor. any ideas?
The final thing is, for any power gains you get by modding a 2.9, you will get the same power or more out of a 4.0 swap for a lot less.
And since there was no computer designed to run a 2.9L with a Mass Air Flow sensor system, it may be dicey to try to get it to run right.
No.Didn't 88 and later 2.9l's have the MAF system?
I stand corrected then. I would suspect, however, that they are becoming a serious rarity though, lol.There are some '90 California models that came from the factory with a MAF.
http://www.therangerstation.com/tech_library/MAF_Conversion.html
I have an 88 and had two 89 BIIs with the 2.9, all three had the speed density system. MAF only came about at the tail end of things when they changed to the 3.0L and 4.0L 6-cyl motors.Didn't 88 and later 2.9l's have the MAF system?
