I got a 7.5 rear end with out any brake hardware or a pinion flange nut for $10 will be swapping on 8.8 backing plates & brake hardware for the time being & also just welded up the entire side & pinion gears in the differential to make a locker.
Whats the the conversion from 8-14 in lbs to ft lbs as I dont have a inch lb torque wrench ,but I do have a ft lb torque wrench,would that be approx 1.5 ft lbs?
