Long and short:
98 ranger
96 Explorer engine/ECU/Engine harness, and I have swapped to the Chassis harness as well.
Are the pin outs on the 3 major 'chassis plugs' the same between explorers and rangers? If not, is there a diagram showing what goes to what? Swap is in, everything is wired, I turn the key to start it, and I hear a relay in the fuse box click, but the starter relay itself *The big sucker bolted on the side of the motor bay* is not engaging, however if I hit the relay's ignition wire post *The red/light blue wire* with 12V, the truck turns over just fine and will start right up.
Input?
________
Honda VFR750F
98 ranger
Input?
________
Honda VFR750F
