- Nov 23, 2024
- Age
- 50
- Dayton
- State - Country
- OH - USA
- Vehicle
- Ford Ranger
- Drive
- 2WD
- 4.0 V6
- Automatic
- Total Lift
- Factory what ever that is.
- Total Drop
- N/A
Well I was able to try drilling out the Y-pipe exhaust manifold bolts some more today.
A made no headway on that and got really irritated.
So I decided to try and get the exhaust manifolds off again and luckily I did make headway on that.
Busted three of the manifold to head bolts on the driver side however.
I got two bolts on the driver side out successfully and have one bolt left in there. I can't get to with my tool I'm using.
It appears I'm going to have to disconnect my steering column.
I need to get to the piece that the steering column hooks to, to lower down so I can get the right angle on the bolt head.
Hopefully once I get the right angle onto the bolt head and get my tool in there good the bolt won't break on me.
After much persistence I was able to get the passenger side exhaust manifold off.
I messed up a few of the bolt heads pretty good though.
To my luck however I did not break no bolts on the passenger side.
Here's 2 pictures of the passenger side exhaust manifold.
This way you all can see my drilling efforts.
I tried a brand new bit today. It too was like it was just sitting and spinning.
Just like the others bits was doing.
I think maybe I wasn't getting enough pressure pushed up against the bolt I'm trying to drill out.
I don't know.
I try different drill speeds and using some oil for drilling fluid.
I know I'm doing something wrong, I just don't know what it is.
Well there's my book for today.
I don't know.
