- Apr 13, 2009
- '06, '11
- 3.0 V6
- Automatic
I've been working on my race truck [91 4.0l/5-spd] for the last few days. I installed some new rear shocks and new shock mounts, and fixed the rear fender mounts and rear bumper. Absolutly nothing to do with electrical. I did some welding but disconnected the battery. I have no spark. It looks like I have some fuel but don't know exact pressure, some fuel came out of the fuel rail when I depressed the schrader valve. My fuel tank is full. My fuel pumps come on when I switch on the trucks master disconnect switch. I read some posts on TRS about no start situations.
I decide to go with the easiest to acces first;
-There is 12v at the red wire at the coil pack.
-I swapped out the coil pack from a known running truck - no change.
-I swapped out the edis6 module from the same running truck - no change.
-If I understand correctly there needs to be an AC pulse from the crank position sensor. I checked as best as I know how and came up with no reading on my multi-meter. It is auto-ranging and figures out ac from dc on it's own so pretty much me-proof, lol. I changed out the cps with a known good one and no change. Did another multi-meter test and still no pulse registering with this cps either. I hooked the leads directly to the cps and cranked the engine.
-The relays seem to be good, I swapped out the green and the brown, but didn't have a black one.
Tomorrow I will r+r the cpu from the running truck, a 94 4.0l/5spd, as long as the cpu will interchange. I had to look mup where it's located tonight or I would have done that already.
Soooo, is there something simple I missed? Any help appreciated as I need this running for this weekends races.
Thanks,
Richard
Thanks,
Richard
