rangermonkey
- Dec 27, 2010
Hey guys let me first thank you for all of your help in the past, this is my first post but I have spent hours and hours searching the archives for past issues on other trucks.
I'm currently working on a 1994 4.0 4x4 with a real rough idle. The only code I was getting was 159 mass air is or was out of range. I replaced maf after a thorough cleaning didn't change anything. Next I checked for air leaks in the intake box/tube. Then I cleaned the throttle body and checked all vacuum lines.Reset the pcm then retested. Same code 159.
I then replaced the Idle air control, reset/retest got code 159 and 513 which is pcm internal failure. The truck always started real well but would idle rough and choke you out with gas fumes from the exhaust. I removed the pcm to inspect it,.no burnt smell but the board was an off color green/yellow. After I cleaned the ground up and reinstalled it it won't start. Now I'm getting codes 159,114 and 116. 114 intake air 116 coolant temp. I'm so lost right now and I need some help. Sorry for the long post.
