- Apr 3, 2008
- Age
- 51
- 4.0 V6
- Automatic
Over the last couple years, occasionally my dash gauges and radio would go off and then magically come back on again. It happened today after starting the truck. I moved the ignition switch a bit and everything came back to life, but I was unable to duplicate it. Could it be the key switch, ignition switch module or linkage? Just looking for ideas before I tear the whole thing apart!
Secondly,
Since I am asking and rarely do so... Occasionally when its hot out and been on the trail for a while where the underhood temps are up. The engine will start cutting out. If it dies, its really hard to start and wont idle. Once its sat for a while it will normally return to normal. I dont remember if the old 2.9 did it or if its just since the 4.0 swap a couple years ago. Again, intermittent issue and generally when on the the trail all day. I cant remember it happening on the road. Anybody experience this? As a side note, it seems to happen when getting the rig vertical mostly, but not always.
Secondly,
