okay, My appologies, before starting truck (when i got her....trailered home) pulled tank, dumped contents, pressure washed, reinstalled, fresh fuel, and filter. have completed three bottles of sea foam (not at the same time). replaced head gaskets last summer due to pass head gasket leak into cylinder. other than tiny "pits" at top of cylinder all looked good. intake runners were dry, plugs then and now are dry. even went to E3 plugs. Am thinking of a reman dist.................
other problem i'm having that i thought i had corrected is no start situations. thought it was FPIS (inertia switch) bought yesterday installed this am, went to leave work this even and a no start. no pressure in fuel rail. never been able to hear/feel fuel pump "running". acts like "vapor lock" (official temp today 112 degrees). any thoughts on this????
BTW thank you for the input.
