timfost85
- Mar 9, 2015
Hi all,
I have a '93 Ranger, 4l 4x4. Sometimes it runs wonderfully with lots of power and acceleration. Sometimes it is a little sluggish. There doesn't seem to be any rhyme or reason to it.
However, I just pulled codes and got some ignition faults:
226 (O) Ignition Diagnostic Monitor (IDM) signal fault - Ignition Systems
124 (M) TP voltage was higher than expected - Fuel control
211 (M) Ignition PIP signal was erratic or missing - Ignition Systems
I don't know if this has anything to do with it, but the ignition lock cylinder is goofy. It sometimes doesn't let the key go in very well and I can sometimes start the truck without a key at all. It takes a different key than the door, so sometime in its life someone must have swapped it.
Can anyone point me in the right direction?
