Ignition control module
HORSELADY12
OK GENTLEMEN HELP A LADY OUT HERE PLEASE!!! I HAVE HAD SEVERAL MECHANICS WORK ON MY 94 FORD RANGER 2.3L 4 CYL 5 SPEED AND NO ONE CAN SEEM TO FIND THE PROBLEM. THE ORIGINAL PROBLEM WAS LOOSING POWER WHILE DRIVING DOWN THE ROAD. HAD TO KEEP MY FOOT ON THE GAS OR ENGINE WOULD DIE, HOWEVER IT WOULD CRANK BACK UP. I HAVE REPLACED THE FUEL FILTER & HAD THE FUEL PUMP CHECKED. IT CHECKED GOOD. THEN 1 COIL PACK WAS REPLACED. THEN THE PLUG WIRES & PLUGS WERE REPLACED. THE FRONT COVER HAS BEEN TAKEN OFF TO CHECK THE TIMING BELT. BELT IS GOOD SO IT WAS PUT BACK ON AND THE TIMING WAS RESET. NOW I HAVE WENT 5 STEPS BACK BECAUSE AFTER REPLACING ALL OF THAT....IT WILL NOT START AT ALL NOW!!!! THE IGNITION CONTROL MODULE WAS TAKEN OFF & TESTED. IT TESTED BAD. THE MECHANIC PUT ANOTHER MODULE ON AND TRIED TO CRANK THE TRUCK. IT BACK FIRED SO BAD THAT NOW I NEED A NEW MUFFLER AND IT BURNT UP THE NEW MODULE. I HAVE GOTTEN ANOTHER MODULE TO REPLACE THE BAD ONE I BOUGHT. I ALSO BOUGHT A MAF SENSOR AS WELL BUT HAVE NOT PUT IT ON THE TRUCK BECAUSE IF THE NEW IGNITION MODULE IS REPLACED, I AM AFRAID IT WILL BURN UP THE 2ND NEW ONE I HAVE BOUGHT. NOW MY SO CALLED MECHANIC IS SAYING I NEED TO BUY A NEW COMPUTER FOR THE TRUCK. I AM AT MY WITS END AND MY POCKETBOOK IS EMPTY. CAN ANYBODY PLEASE PLEASE HELP ME OUT????:icon_twisted:
Stop posting these questions in the EVENTS forum. Putting this stuff in the General Discussion or the 4-cylinder areas will get you many more useful responses.
Didn't realize I had it in the EVENTS threads. Will try & change it over.
