Only in gear huh? Get a manual. Not too up to speed on auto's, but I'm still leaning towards the vacum idea. Found some stuff poking around on the web. Maybe look for leaks, or crappy lines down by the tranny... , or get a manual.
Have you tried putting it in one of the "set" gears? Try putting it in first, and take away the trannies ability to "think". According to the excerpt below, if your truck has one, a bad vacuum modulator could confuse the tranny, and make it not decide on a gear. Beyond that... get a manual.
* The Vacuum Modulator monitors engine vacuum by a rubber vacuum hose which is connected to the engine. Engine vacuum reacts very accurately to engine load with high vacuum produced when the engine is under light load and diminishing down to zero vacuum when the engine is under a heavy load. The modulator is attached to the outside of the transmission case and has a shaft which passes through the case and attaches to the throttle valve in the valve body. When an engine is under a light load or no load, high vacuum acts on the modulator which moves the throttle valve in one direction to allow the transmission to shift early and soft. As the engine load increases, vacuum is diminished which moves the valve in the other direction causing the transmission to shift later and more firmly.
