idle problems
kiehn18
Hey guys, im new here and really glad i finally found how to post. Anyway, im having problems with my idle after i drive around and get it warm then shut it off start it up again it gets a really bad idle like there is no idle air control. Which i have replaced. Also when i give it gas cold or not it acts like its not getting gas but it idles fine and if i get just the right spot it will accelerate fine.
Things i have replaced:
-idle air control valve
-egr valve
-egr position sensor
-MAP
-All vacuum lines
-Fuel filter
-Fuel pressure regulator
-Injector o rings
-O2 sensor
-Cap and rotor
- Plugs and plug wires
-Air filter
-Oil and oil filter
-Timing belt
All this has been changed within the last 200 miles.
Codes came up with a temp sensor but that was it.
Working with an 86 ford ranger 2.3l non turbo :bawling:
a bad coolant temp sensor will give you an idle prob.15 bux. fix it.
Thanks, ended up being tps and new spark plugs again
