Spec is 40-50psi
Also if possible check fuel pressure gauge on another engine or even a tire that has a known pressure, gauges can read a few pounds off so best to have a baseline test of a known pressure.
Fuel pressure regulator(FPR) is opened and closed by vacuum pressure in the intake.
Vacuum is highest at idle so fuel pressure would be lowest at idle.
Pull off the vacuum line on FPR and check it for fuel smell, if fuel is present replace FPR.
42psi is a bit low with FPR's vacuum line disconnected, this would either be from an older fuel pump or a small leak.
What was fuel pressure with engine off, it should drop a few pounds then stabilize, and stay without dropping any more, if it continues dropping then there is a leak, if there is no gas smell anywhere then could be FPR valve or an in tank leak, i.e. fuel pump check valve(back flow preventer)
But the 32-42psi should be fine for engine operation, the computer would open injectors longer when O2 sensors report leaner burn from lower pressure.
