PsYcHo_FrEkE
- Apr 15, 2014
- Automatic
1997 Ford Ranger 4.0L EFI.
I just finished replacing VC, IM, TB, Fuel Rail... etc. About all of the gaskets in the upper end to fix a P0171 & P0174. I had to replace the pintle caps on the injectors. I used the generic blue ones from the parts store since they were all that I could find. Put it all back together (all torqued to spec, then upper intake manifold torque re-checked), flushed the engine and the radiator, and it was running great... until it warmed up. I replaced the IAC about 4 or 5 months ago. Warmed up I now have an idle issue that wasn't there before (at least not since I replaced the IAC). IAC checked 10.6 ohms. Seems to run okay going down the road, but tries to (and occasionally does) die when I stop the truck. . I can feel the loss of power as I let off of the accelerator. I'm doubting the problem is fuel related since acceleration seems to be fine. The erratic idle is prominent throughout the full RPM range when sitting in neutral. Currently, there is no CEL. I have posted a youtube video of the problem. In the video I circle the engine to try to isolate the problem if it's a vacuum leak and to double check all of my connections (again).
On a side note when it first started doing it I sprayed some brake cleaner on the upper intake around the seam and the idle straightened out. It only worked one time. I was unable to replicate this. Spraying brake cleaner there now does nothing to change the idle. The only thing I can think of is that perhaps the upper intake manifold is coming apart at the seam or is cracked somewhere underneath. Does anyone else have any opinions on what could be going on here?
http://www.youtube.com/watch?v=1aAfWg3uVKg
