DriverSideImpact
High Idle
My 1996 2.3L has had a strange idle problem for a while, mainly just this winter...so I guess when its cold out. It will hang up high, around 1500-2000rpm, in between shifts and when at a stop. Once I'm totally at a standstill, if I engage the clutch a little bit, the idle will drop back down and stay there. It's rather annoying and it messes with my shifting. Another thing I've noticed is there is a rather large lag if you blip the throttle.
So I have been searching around for causes of this and I can't find anything. The PO put in a new Idle Air Control on. I recently put in a Throttle Position Sensor. Some of the vacuum/air tubes off the the intake tube, throttle body, and valve cover had been taken off by the PO, but I made sure those holes were plugged and the valve cover has a little breather filter on it. There's no check engine light, no trouble codes, and it passed state emissions a few weeks ago.
I'm not sure what too look at next, or what to look for. Ideas? Suggestions?
