ideling down, problem????
dwfronk
truck 98 ranger 3.0 5speed 4x4. While driving down the road around 60-65 mph 5th gear approx 2500rpm i can push in the clutch put it in neutral and it will idle down to around 1500 rpm then when I come to a COMPLETE stop it will idle down slowley to normal (around 700rpm). at diffrent speeds it dose the same thing idels down to about half or so from what 5th gear would be then stop and it will idle normal.
My check engine light is on and i have ran the obd2 code it comes back EGR flow insuficent. I have replaced the EGR valve and the control piece for it (sry dont remember the exact name).
So dose anyone else have these problems and what can i do to fix them. And could they be related?
P.S. thanks for all the help.
