- Feb 11, 2013
- Automatic
Where's the best place to buy a reconditioned ICM for a 1986 4 cyl 5 sp ranger? I see a lot of suppliers out there on the net but want a good quality one.
I've got a rough idle problem that lasts a minute or so then straightens out but happens every time you shut down and restart. I.ve replaced oxygen sensor and temperature sensor. It used to do it then straighten out but now it's effecting the normal performance.
I don't want to start changing everything out cause I read that it is probably the ICM----BUT---- ??????
Engine rebuilt about 40,000 miles ago --sounds ,starts and idles great--just starts up idles up then settles----then rough idles and blows black soot out the exhaust for a minute then goes back to idling smooth. It used to do this and run good if you let it go thru it's routine but now it's not clearing up and is missing and bucking while normal driving.
