Dustin_89BII
Hi folks. Just rebuilt the 2.9 from my 1989 b2 4x4 and fired up. Still having a low and erratic idle. Got koeo codes 12 & 13 at one point.
I am going through the diagnostics for the iac. Here what I’ve done so far:
1) multimeter test of iac unit : 10.7 ohms. (7-13 is spec).
2) multimeter test of iac connector : 11.58 volts with key on engine off. (~12 is spec, of course).
3) Test of iac unit connected straight to battery to test function of “plunger solenoid” or whatever it’s called. It jumps about 3/8” when power goes to it. (From what I’ve read, that’s the travel to expect).
4) koeo and iac detached from plenum. I plugged connector into iac — no visible change/movement in the solenoid/plunger.
Shouldn't the plunger move if I plug in the iac unit with the key on engine off? (Cold engine) .
Do these tests imply that there’s some kind of issue with the EEC/PCM not sending a signal? (Pin 21 gry/wht wire).
Do I need to test continuity on that wire? I’ve never gotten into the PCM, and don’t know how to do that. Any assistance on this would be great.
Thanks!
Thanks!
