DaNgErOus1998RaNgErOuS
I have a 1998 Ford Ranger 3.0....recently the truck started to hesitate and sputter and now it will stall out and act like it is running on half the cylinders....SOMETIMES. Other times it will run ok but is lacking the power. I know there is nothing wrong with the motor itself because it is a brand new remanufactured long block. I would give you guys the codes that it is turning up but the OBD sensor will not let me read any codes, and all the fuses and connections are fine. At first i thought i may have been a fuel pump or catylitic convertor, but then again it will run fine sometimes. I had a guy look at it and he said that especially since its not letting me read codes it is the ECM. Any tips or pointers will help, I just need to get this thing back on the road!!!! Thanks!
