I need some opiniones
Robert_1967
White Pine, TN
I just got a 93 F250XL Kingcab, 5.8lt engine, auto trans, manual transfercase, auto hubs, it has 8 lug axles, can anyone that is more knowledgable in these areas, what type of axles do you all think is in this truck, and about how much are they worth, I'm thinking of parting the truck out and useing the engine in my 88 Ranger supercab, so if anyone can give me a good heads up about what the truck has or might have and how much they are worth, please let me know.
Robert
10.25 rear, 44front
'93 will most likely have a D50 front, and the 10.25" rear.
The 10.25 is a nice strong axle with lots of aftermarket upgradeability. The D50 will be the TTB version with leaf springs, which IMO, is a stupid setup (leaf springs move in a straight line up/down, whereas a TTB beam moves in an arc, = binding with more than a few inches of movement). TTB D50s aren't worth a whole lot on the used market, although some guys go after the hubs and spindles to convert DRW D60s to SRW axles.
Yea, I notice that the front was a stuiped set up, twin beams with leafs, well, if someone wanted to convert the front to a solid axle with leafs, they are already half way there.
I'm going to have to pull the engine and check for a cracked block, all the freeze plugs are out :(
thanks fofr the help.
Robert
