storejl
- Jan 6, 2011
I have an 87 ranger that is having a lot of major issues. The biggest issue right now is that it is stalling out. When I try to start the truck it takes a few tries. Normally it doesnt start on the first few tries. Then when it does start it will die a few times until it finally can run without me hitting the gas. But when it does run it runs really rough. Then the issue is when I hit the gas. When I intially push the pedal it dies off (the rpms fall and it sometimes kills the truck.) So far I have replace the fuel pump, fuel filter, fuel presure regulator, spark plugs, spark plug wires, throttle position sensor, exhaust from the headers back, and some other various parts. So I have a few questions.
1. If anyone has had the problem that I am describing and how they fixed it.
2. (This may be my problem) It is a CA truck so it has all the extra smog control additions. When I replaced the headers they didn't have the port for the hot air return to the trottle body. Would this be causing the issues I have and if so, where can I buy the correct headers?
Another issue is that my insturment cluster lights are malfuntioning. The only one that turns on when I start the truck is the seat belt light. I replaced all the bulbs and the fuse and they still dont work.
Any help with these issues would be very appreciated.
