I need help puting after market tach in 95 ranger
jch133
i bought a tach lately and put it in a 86 mazda B2000 and it worked which had a ignition coil but i want to put it in (95 ford ranger 6cyl 4.0L EFI) but it has the distributless system so i dont know where to find the power control module to get rpm feed to tach, it says under 95 ford ranger 6cyl in papers with tach the pcm is under passeger side dash but i cant find it its supposed to be a tan wire with yellow strip but i cant find it i found one but it doesnt feed any power to tach , please help i got it installed and it moves needle when i turn key to acc position but the needle doesnt go above when i turn key on
in the engine bay on the fire wall find the computer.. should be right infront of you.. the harness coming off the computer which goes to your engine thats the harness you need to tap into .. i did it to mine right their.
