I need help fast!
All I know is that a 1/2 bit drilled off the rivet heads in about 2 minutes, so the 94 ranger frame is nothing very special;.
You do realize the rivets and the frame are 2 different things? :icon_confused:
Also, if I understand this correctly, you don't need to mod the frame at all. A long wheel base Ranger is a super cab short bed.
You understood wrong...
The supercab has its own frame. Note how the frame drops under the cab... That section is longer on a SC frame.
A RC/LB frame is essentially the same as a RC/SB frame, there is a 6" difference just forward of the front leaf spring hangers.
I had to say something, I've seen that same comment here a lot lately...
Sent from my PG86100 using Tapatalk 2
