blh0007
- Jan 16, 2009
- Automatic
Hey guys, I have read the tech article in the tech library about how to get your lights brighter... there is one idea where the author came up with a relay set up where both the high beam filament and low beam filament are on at the same time when you have your brights on... if i am not mistaken i think that the flash to pass switch in the multi function switch switches on the high beam while the low beam is on too... would it work if you just swap the high beam and the flash to pass wires in the multifunction switch. It seems like it would work, but i am not sure if there would be an added load on the multi function switch. I don't think that there would be but i am not an electrician so i was looking to get ya'lls input. thanks
