I have a friend with a problem...
rumblecloud
5+ Year Member
⭐Supporting Member
MI - USA
Vehicle
1-1/2 inch front leveling
Stock
What's the worst that could happen?
On my Facebook feed, I am a member of a Ford Ranger group. One of the guys there s having a squuirrely issue with his brakes and am wondering if it would be ok for me to relate his issues here? I'd be kind of a middleman unless he decides to post it himself -- I did invite him to join. Please let me know.
Basically he has rebuilt his brake system and has no pedal when the truck is running. Hard pedal when truck is off. It's a 94 Ranger - like mine.Thanks in advance. R
Sounds like a blown booster.
Have him pull the vaccum line off it and see if they stiffen up
Hey Rusty..Thanks for your response. He has done a lot of different checks and taken the logical corrective measures, but I didn't want to detail them until I got an okay to even post this request. I will compile it in a sensible order and repost when I get it together. Obviously it would be much easier if he just did himself and maybe he will jump in later. He has visited here before not sure why he doesn't want to/or just hasn't joined. He'd get a much better response here than FB for sure. Stay tuned...
EDIT: I will ask him to do that...thank you
No offense to Rusty... but if unplugging the vacuum line at the booster results in a firm pedal... it proves nothing. We already know the pedal is firm not running. It sounds like the booster is working just fine to me.
Two things come to mind for me...
Some air still in the system
Rear brake shoe adjustment
You're OK to post this question here @rumblecloud
We're always willing to help out a Ranger owner...
Actually thats a good point.
But id still bet on a booster. Even with rear brakes way out the pedal shouldnt hit the floor.
Did 94 havE ABS?
Dammit...thought I posted this yesterday. The RBS was what I was thinking also...
Here are some more details:
Replaced Master Cylinder
Booster
And a one brake line
Bench bled the master
Claims good fluid flow from all four bleeders - bled properly farthest away to the closest using the buddy system
Calipers are installed with the bleeder up
Good vacuum at the booster
Things I've mentioned:
RBS proportioning valve but no response on that
And obviously air still trapped in the system at the rear
Can the proportioning valve cause this (brake to the floor when running.)
that's all I have for now.
Thanks
Did he mention if the brakes still work... but a really low pedal?
Also... when the rear brakes are properly adjusted... engine off... the pedal should have a small amount of free play at the top but be solid as a rock. If the pedal does any amount of travel to get solid... the rear brake adjustment is off.
I should also add that if you get good fluid flow at the rear bleeders the RABS Valve is flowing.
Event Coverage
TRS Merch
