JTH1972
I know I have this in another thread, but I could really use some help figuring out what these mean.
Okay, I just did the KOEO test and it flashed 11 twice, long pause then one pulse (seperator), another long pause, then it flashed 34 twice, which according to the codes is:
EVR - (O, R, M) EVP sensor is/was high - EVR
PFE - (O, R, M) PFE sensor is/was out of range - PFE
I'm not familiar with the acronyms, so can someone help?
KOER Test as follows:
1 pulse
light flickered
21 - Engine Coolant Temperature (ECT) sensor out of range - ECT
33 - ALL - (O, M) EGR did not open/ respond during test or if memory code, did not open intermittently - EVP EVR PFE
77 - System did not receive "goose" test - see TESTS
25 - Knock sensor not tested (ignore if not pinging) - KS
21 (repeated)
33
77
25
Translation help please? So far from the KOER test I'm going to have to replace the EGR valve and coolant sensor, correct?
1 pulse
light flickered
21 (repeated)
33
77
25
