alright, here it goes.
i started out with a 1990 ranger, standard cab, 2.3 4cyl, 2wd.
i swapped in a '85 F-150 302 (30 over), '83 F150 cast iron intake, '83 F150 cast iron heads, '83 2 barrel carter carb, mechanical fuel pump, manual choke, vacuum advance distributor also '83, only h2o pump and alt, no power steering, no a\c, no smog, no egr, true old school engine, Trans-dapt 9736, 1113, hedman 89500, PA 3" body lift, 92 mazda 5 speed tranny (tail shaft modified for tranny speedo instead of rear axle speedo).
im new to customs but have 6 years of experience in repairs, and quite frankly guys im flat out stuck, i have a battery drain that takes my fully charged battery 12.87V and takes it down to 1.12V in less than 10 hours, i also have many wires from the new V8 that i do not know where they would attach into the 4cyl harness, i would like to get rid of the computer and all the excessive wiring, i have been working on this truck bit by bit for 7 months.
i also do not have a radiator that fits or rad hoses that fit, im not a ford enthusiast but i wanted to learn something new. i could really use any kind of advice, tips, and know how, i have very good background knowledge but i have stretched it to my wits end trying to figure this out.
