bubba cakes
- Dec 5, 2008
Let me start by saying: I'm as dumb as a box of doorknobs.
I was driving home in the rain a few weeks ago, and the engine just stopped running. the timing belt had snapped.
i replaced the timing belt (it was an ordeal for me for various reasons related to living in an isolated area, not having all the tools i need, not having transportation, etc). i started the engine. it ran awful rough and the valves were clattering like mad. then the engine died. it was the last time it would ever run.
i have since heard that if the timing belt breaks while going 40mph, that there are probably some bent valves.
i didn't put any anti-freeze in the coolant, 'cause i was going to have to do more work on it. (this is called "foreshadowing", where a sentence pretty much tells what is to come.).
while planning my next assault on the engine, the temp in my neighborhood dropped to zero overnight.
hahahahaha
yes, the block cracked.
now i'm really starting to have fun!
so now i need a new motor. my situation is complicated by the fact that i am retired, living on social insecurity, and apparently i'm also retarded.
so, i need a cheap, second-hand engine in good condition. i found one for $400. i'll call again and ask for compression readings for each cylinder. what else can i ask for? they already told me it's got 97,000 miles on it.
this would be a good time for a turbo swap, right?
a second salvage yard said that the only engines i can use are from a truck like mine: 95 B2300, and 95-97 Ranger engines will also fit. Wicked Sludge mentions that there are many others that can be used, including turbo 2.3's. do they just fit right in there, with all bolts lining up and everything, or is it a mechanic's challenge to make it fit somehow? can an idiot like myself do it?
thanks!
hahahahaha
thanks!
