SuperRob
Ok....so I started the drive back home with no 4th gear from Alberta to Victoria, and then all of a sudden my clutch goes. Gone...Nothing....(except smoke and smell)
So I refill the reservoir and it pumps dry again right away without even so much as a hesitation. My initial reaction is that the slave cylinder is shot. There is NO clutch fluid anywhere except below the bell housing, the lines are all dry and everything.
Oh as we get started I have the Mitsubishi Transmission.
Q. 1) Do you concurr with my diagnosis?
Q. 2) After all this reading I've done I've realized that I have to take the transmission out. any tricks you are willing to offer to make this job easier? Is it easier to split the TCase? If so will I lose fluid from it?
Q. 3) Whats up with this bleeder that the clutch has, its just a bolt with a hole in it? LAME-O. Any tricks to that?
Q. 4) When I take the shifters out, I guess you have to pretty well totally disassemble the linkage for the t Case, and for the transmisson, do you take the 4 Torx bolts out or take the (6) 12mm bolts out to remove that cover?
Finally, anyone in Red Deer Alberta wanna give me a hand for their favorite cold beverage?
Thanks.
Thanks.
