- Aug 6, 2007
- Age
- 45
- Western Michigan
- 1975-1995 Ford
- Automatic
Yukon 4340-
5-760x Joint.....the cross shafts (center section) still had the one cap on it when i found it. The other cap was still attached to the ear of the shaft and the c-clip still on the cap. The other two caps were MIA
The break was instant, had a loud crack bang and then nothing. So it appears all the ears broke at the same moment. When i broke all my stock shafts, they made a god awful sounds of the stub and shaft hitting each other as it turned. With this failure, there was just the intitional bang and nothing, i thought for sure i had just broke the hub.
I have stock Hubs from a GM D44. They look alot like a warn hub inside, with the cast insert ratcheting peice. I honestly thought that would fail before the shaft or joint. I thought the hub would have been my weak point. I used to run the old ford style hubs that were pretty much unbreakable. I lost lots of shafts with those hubs. Are the Warn Premuims really that much weaker? I was gonna look into the Fuses but i have read they are discontiuned, and with chromo shafts the fuses will just break extremely easy anyway.
