to quit all the dumb, bull headed and ignorrant responses and give the guy the answer he wants. mine runs on avereage of 200* crusing the highway at60 mph. just after accerlation it goes up to 230ish then drops back down to 200*. now what was wrong with a simple answer like that??!!!
dang the guy had a simple question and didnt need all the cocky and bs answers!! we are all ranger lovers here so show the guy some respect!!
The answer someone wants isn't necissarily correct and could be at the very least be misleading.
As for temps I have mine guaged not only with the factory guage, but with a temp sensor in the feed to the cabin heater core as well as both sides of the radiator.
My temp readings aren't necissarily translatable to anyone elses, so...
But I will say that if I see a temp as high as 150F on the return side of the radiator I'm going to be spending time concentrating on determining why.
in geral a temp guage that see-saws up and down in steady state operation (highway cruise) is a symptom of a problem and that problem is usually
a thermostat in immediate need of replacement.
a cold thermostat creates other problems because EEC-IV engine management KNOWS what the temp of the coolant is, and while '85-92 EEC-IV only outputs "pass/fail" readings to a scanner the 1993-up with the proper reader can give real time outputs from all the sensors to reveal "almost right" readings and I can tell you that the computer KNOWS how warm the engine is and if it isn't "warm enough" (like when a 160F T-stat is installed) the engine management will never leave "open loop" operation and as a consequence will run piug rich and create all sorts of problems.
Before you start ****ing around with stuff you really need to know how things work.
like all things in life if you want to play the game you must know the rules
and if you want to cheat you need to know them even better than everyone else.
Lastly Don't ASSume that all these lengthy posts are specifically adressed to the original poster most of the comments here are adressed as general "disclaimers" to the great unwashed masses of lurkers in any given toipic who will read but never make a post of their own.
what we discuss is read by many.
And we must adress those people so they don't get the wrong ideas by taking something out of context.
AD
