How to wire a volt gauge
Mightyfordranger
Ohio
2.9 V6
3in
Clean your room before you criticise the world.
How should I wire up my volt guage just right to the battery or splice into something???
If it is a Voltage gauge not an amp meter then yes, just hook it to a Ground and a "key on" 12volt wire.
Voltage meter is a draw on the system, not much but not nothing either, so best to have it off when key is off.
I just ran a wire under the dash into a blank space in the fuse box on my 84 Bronco 2. Seemed to work just fine.
