Welcome Visitor! Please take a few seconds and Register
for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
And you'd rather hit one of the furry ones with your car than that green one.
I don't know if wresting those tires or busting track is worse. A track is like a 500# slinky. I didn't feel like spending a week turning the idler wheel adjustment nuts with a big wrench so I used a pair of come-alongs to pull the idler back so I could get the track back on. And a few ratchet straps were handly to help pull the track over and hold it so I could get the pin in.
The trick is to make sure you keep your lips over your teeth when messing with these things.
We're getting ready to build a pond so I've been messing with my other two machines--repacked a cylinder and replaced a seal on a spool valve on my hoe and now am adjusting the chains on my Bobcat. This thing has almost as many chains in it as a SOHC 4.0 Ford.
