I've read/printed the tech library description, any other tips to find a leak. I am currently loosing vacuum whenever I push down the gas, to the point of the vent louvers closing.
Well, you normally loose vacuum when you depress the accelerator. Are you finding that you really have to put your foot into the get the truck to move? The vent door closing is a fairly common problem but it should only occur when your at or near WOT.
then it may not be a leak. could it be plugged exhaust? check out this link. use a hand vac pump (sold as 'one man brake bleeding kit') to check actual values
it could be the vacuum control switch, but most likely it is the check valve between the manifold and the vacuum tee, or the line to the hvac. You can pick up a generic check valve at most auto parts stores for less than $5, just make sure you connect it to the hvac line only. and make sure you install it in the correct direction as it allows vacuum only one way. On one side of the valve it might say engine, source, manifold etc... that side goes to the engine.
For
