how much
couple hundred tops.
It's worth more in parts than as a whole truck.
i know but im tryin to get the whole truck and swap the trans and motor in my ranger and use the axles for my b2
around here $200 to $600
no pics, all glass exept doors(cause windows were down) and back glass are broken, driver door dont open, no mirrors hood/fenders/bedsides crushed... guy said it rolled 4 times and came to rest on its side.
Low miles? I'd think around $400-$500. It sounds like the parts that you want from it, engine, transmission, axles are about all that are good anyway, everything else would pretty much be scrap.
Last I heard it was somewhere below $300 a ton for iron, and vehicles bring less.
It is a wreck with a junk body and axles, depending on if it killed as it was rolling the engine could be shot too. Only thing it has is a flakey engine, transmission, t-case, some interior stuff, and probably at least one stained seat.
I would rather buy a mint '96 with a blown A4LD for a couple hundred bucks.
Engine, runs fine he drives it in his yard. I heard it run. Axles arent damaged, he said it was not a bad rollover it just rolled down a ditch! Goon to look tomorrow if his job let's him out early enough
