How much refrigerant to add to 96 ranger 2.3
bnrr
I need to know as to how much refrigerant should I add to my a/c system?
I will be replacing just about all the a/c parts with the exception of line/hose.
all the parts; compressor, accumulator, orifice tube, evaporator, and condenser are all new. I do know that I would have to flush out the line/hose, add the correct amount of PAG 46 oil to the compressor and accumulator, do deep vaccum after installation, but I am not exactly sure as how much refrigerant should I charge to the system, is it 1lb 7lb? (r134a sys).
I was also told by my friends that I have to add oil to the condenser:icon_confused: if this is true I need help as to how this is done.
With all this new parts I want to do everything correctly, as I do not want to damage the parts where I would have to start all over again. TRS community please guide me :pray:
Thanks
Put 4-5oz. oil into the compressor, the rest can go in the accumulator.
Required amount of refrigerant should be listed on the top or side of the A/C evaporator housing under the hood.
AllData says capacity is 1.38 LBS refrigerant and 7oz. oil:icon_thumby:
Thank you 4x4 junkie and 2813 josh for the reply to my post. I am sorry I did not reply sooner, have been quite busy for some time. now that I have the information of the require amount of refregerient and oil for my system, I can get started. thanks again guys:icon_thumby:
Mine took 2 12 ounce cans and it works awesome.
