fletcher969
I was wondering how much rotational play is considered acceptable on the rear axle? I've got about 1/2 inch or so I can rotate my rear hub.
Thanks.
Thanks.
Idk how much exactly is normal, but it sounds about right... if you're really worried about it, take your diff cover off and check out the gears for wear. Is your rear end making any odd noises or acting funny? If it isn't, you're probably fine.
How have you ruled out power steering? Does it do it only when you do something else?
Doesn't sound like anything unusual to me either.
If there's not a lot of in-out movement (less than 1/8" or so), and doesn't wiggle up-down & around at all, I wouldn't worry about it.
