how much lift are these good for?
Since the description says 3.5", I'd say they're good for 3.5". :icon_twisted:
haha but theyre for a cherokee, and if i put them on my 94 supercab 3.0 ranger would i get the same amount of lift?
thanks, they also have 4" wrangler coils for $113.. would they give me 4" of lift or are they gonna be a nice bit lower cause well, a wrangler is a lot light than a supercab ranger lol
well first off why are u useing jeep coils? (just wonderin) and after driving and siting theyll sag a little but at the max a 1/2''
cause i read alot of info in the tech library and from 4x4junkies posts, ttb coils are very stiff and his truck flexes like a boss with jeep coils
I would say they'd give more lift than that.
My experience is with the 3.5" EB coils. I had the 6" JD brackets and put the 225 lbs/in coils in my Explorer. It raised the front almost an inch over the 6" Ranger coils.
cool, do those EB coils flex any better than the ttb ones?
dam.. thats good to kno.also saw your build thread keep up the good work:icon_thumby:
My Ex with 3.5" EB coils and 35s
ok, that looks perfect!
so use 6" brackets with them?
Yeah those Jeep coils will probably be too soft for your big Supercab truck.
The EB coils are what you want, though I would look for linear-rate coils that are rated around 300PPI, not progressive-rate ones (you can tell linear rate ones from all the windings being evenly spaced).
I assume you've got some plans worked out for your steering setup?
