How much drop?
Mr._Graybeard
Antioch, IL
This is probably an easy question for someone who knows that they're doing -- unlike me.
I have a 2005 FX4 with Class III hitch. I just picked up a heavy-duty 5x8 trailer to haul fuel home for my pellet burner. I brought home a ton today and noticed that the trailer deck isn't quite flat. I think I'll probably need to get a hitch bar with at least a 3-inch drop vs. the 2-inch drop I have. The trailer has 14-inch wheels, BTW.
Any thoughts? Thank you kindly.
it's all about trailer hitch weight and how you distribute the weight on the trailer i believe you should be about 400 pounds max on the tongue. i trailer a coleman e-3 trailer which is about 2800 pounds dry. so you want your drop to level out your trailer with the weight you have on it at the time. if you you get your front end up too high you will have trouble steering on corners or fast bends.
More costly but you might be able to put larger wheels and tires on the trailer, depending on how the fenders sit now. BTW, if you wanna do this, most trailers use the same lug pattern as our trucks. I once had a truck with trailer wheels all around.
Thanks for your opinions gents. The trailer is 20 years old but the tires and wheels are brand new, so I think I'll stick with them. I'll go shopping for a new drawbar instead. That should level things out.
your welcome i hope i made a little sense there fyi i have several drop arms of different heights so i can adjust the level of what i'm towing and keep the hitch weight where i want it or you will push thru the corners if your front is up too high ! good luck
place your trailer on the level, measure from the ground to top of the inside the hitch where the ball sits, probably somewhere around 17" then take that measurement to your truck sitting on the level and measure up to the trail hitch height , The difference from the bottom of your truck receiver to trailer measurement is your drop.
Hope thats not too confusing. It would very difficult to measure the trailer loaded and have it pull level, it would depend on carrying the same weight all the time. Make sure the trailer is loaded with weight distributed evenly.:icon_thumby:
I'll give that a try tomorrow -- thanks.
Just an update -- after running with the trailer hauling several 1-ton loads I found that Muzzlestuffer's advice worked for me. Having the load forward of the trailer axle levels the trailer out, and, I think, contributes to a more stable ride. Again, thanks.
Thanks for update.
sent while sitting on the throne
