How do I set up wireless security?
exbass94
Guilford, CT
At my house, I have 2 computers. One connects to the internet via an ethernet cable straight to the router. The other connects to the router wirelessly. I want to enable security so my neighbors can't use my wireless, but I can't figure out how. I can click on my wireless network and enable the security, but as soon as I do that, my computer can't connect to it. If I click "connect," the computer will then connect no problem, but it automatically disables the security! How can I enable the security AND have the computer be able to connect to it?
There are ways to do it, none of which I can think of at the moment. What you can try though is to run the setup disc that came with your router. My router install disc took me through the steps to set up security. If you have the disc, you might be able to skip through the steps you don't need and get to that part of it. Not a great answer, but I'm tired....
I believe that the hardwired computer is the one you have to set up the security on. You have to set your WEP or WPA or whatever before you can securely connect wirelessly. I know once that's done, on the computer that's connecting via the wireless router, if you right click on the wireless internet icon on the taskbar, go to "view available wireless networks" and choose your network, it'll connect, ask for your security key and then it'll work.
What you need to do is have the computer thats hard wired to the router go into the internet and in the address bar type in, 192.168.1.1. Hit enter and it should bring you into the router settings. From there just look for a security page and it should be in there to setup anyway you want. What kind of router do you have offhand?
The admin and password for the router will differ depending on the manufacturer.
For example, Linksys are usually username: admin, password: admin
D-Link are usually username: admin, password: blank
Netgear are usually username: admin, password: password
The security can be configured from any machine that has access to the router, but if you're setting up wireless from a wireless system, you'll lose your link as soon as the new settings are applied.
Oh ok, I'll have to try this out later when I get home. It's a Netgear router. I seem to recall it has a default username and password printed on the back of the router. Thanks a lot guys!
don't mess around with the cd it came with just 192.168.1.1 into the router via your browser. Also us WPA2 for wireless security not WEP or WPA.
