How can I tell my ABS setup?
James Morse
1997 XLT 4.0L 4x4 1999 Mazda B3000 2wd
Roanoke VA
1997 and 1999
31x10.5-15 K02's on the Ranger, 235/75R15 on Mazda
The perfect is the enemy of the good.
I should have rear ABS as standard. 4-wheel ABS was an option. What should I look for to tell if I have 4-wheel ABS? Not a big deal one way or the other, I just like to know what I have.
Brakes work terrific, I haven't locked up rears yet in normal/medium-hard braking. They had just put new drums/rotors so assuming that's true, they -should- work good.
This is about the XLT.
Thanks. I don't see that unit at all so they didn't get the optional 4ABS.
I can live w/out the optional 4ABS, actually could live w/out any ABS, really, and did for many years.
It can be nice in a panic stop I suppose.
Questions:
Since there is no unit there besides the master, where does the "pumping" of the ABS for the rears get done? I see the one sensor but I'd assume that's for the fluid level.
If I ever had the crazy idea to do so, which I doubt, could it be added? I guess there's have to be a sensor at the wheels... sounds like not worth it.
Here is pic of the '97
Follow the Front brake line on the Master down to the drivers side frame rail, it connects to the RABS valve
