- Aug 26, 2008
- Automatic
- My credo
- Failing is easy. Everyone can do it.
Well...consider my nads' frosted.
Took the ol' girl in for the yearly inspection, had to replace a parking brake cable and wiper motor. (we knew that would fail, so we did it prior)
The shop took the truck in...and bombed it.
Quoted to the states DMV computer: Service brakes bad, and suspension bad.
The inspector said my brake rotors failed, and my wheel bearings where loose.
OK...so the rotors are scored up. Still in decent shape actually with no 'chunks' missing or bad spots. But the inspector failed it saying "On a scale of 1 to 10? You're on a 1.5".
As for the wheel bearings? They where correctly adjusted, and most I've done in the past have a tiny tiny amount of play over the years. He stated "No play is acceptable". I can drag out the repair manual with the specs that states the exact amount is considered acceptable "Play" with wheel bearings. The play was so minor it's laughable. (and I USED to be a state inspector!!!!).
Anywho. I figured I'd change out the rotors and give it a proper brake job. It does have some pedal pulse. One rotor came from China--looks like a crap machine job. The other? From Canada. Looks 100% better. Same brand name and store--just one was older stock. Put in new bearings, etc...So the wheel bearings now have no play at all with correct adjustments. (go figure? They are new after all, give 'em two years? (I installed new bearings two years ago) And I'm sure they will wiggle slightly LOL). Even put new pads on it.
Finished it all up...and the right caliper started to hang up. Even with the new hardware kits and all the wire wheeling...lube.... The piston only retracts 1/2 way. It didn't like being pressed back into the bore to make room for the new pads.
I picked up the reman from Napa. With luck I'll finish it tomorrow and have the reinspect done on Tuesday. It's NOT going back to that shop ever again. And of course, once the computer logs in with my registration? It will pull the records of why it failed in the first place, and the next shop will have to do the whole thing again.
This shop even went as far to just about tear a rear drum off the back. Even though I had one side off for the parking brake? They thought the passenger side with the old cable would flunk. (news flash...It got rebuilt two years ago, shoes, wheel cylinder, hardware....) They must have been disappointed after having to pry the drum off--to see everything was still 'mint'.
Just venting at this point. I'll go back to the other shop my parents use...I figured this one was legit after they helped us with our tibby (wifes car)...But they really tried to hose me--picture the look on their face when I said "If it fails? It fails...but I do all my own repair work" The parts alone came to $180....Picture paying list price and labor to the shop!
S-
S-
