mister moose
- Jan 16, 2014
- NW CT
- 4.0 V6
- Total Lift
- None
- Total Drop
- None
- Tire Size
- OEM
- My credo
- Never work on a powder day.
This all started with a sticking caliper. "try replacing the hose" was the advice. Apparently some old hoses deteriorate and self seal?
Anyway.
02 Ranger XLT 4WD 4.0L
The usual snowball issues - frozen bleeder, frozen flare nut at frame fitting, etc. Got them off after lots of coaxing, except I think I twisted and stressed the brake line on the frame as the flare nut was sticking to the line. Replace caliper as mating surface was heavily corroded and resealing looked bleak, plus it's a 16 year old caliper that has seen enough road salt to melt a VW.
So the new NAPA brake hose does not fit the new NAPA caliper. There is a raised edge to the hose end fitting that is shaped like a skinny "C". In order to fit, it needs to be shaped like a skinny "L". The extra ear of the "C" keeps it from fitting. Advance Auto parts had the exact same issue.
Has anyone come across this? Have a solution? I'm off to the Ford dealer on Monday, but thought I'd ask in case there's some helpful knowledge out there.
In the photo below, the shaded area is the ear of the "C" that is in the way.
Thanks.....
Anyway.
Thanks.....
