horn relay
poboyz
I have a 94 ranger that i need to replace the horn relay. Does anybody have any idea as to where it is located? I have talked to 4 different ford dealerships only to get 4 different answers. I can be emailed at poboyz_5@yahoo.com thanks for any help anybody can provide
93 schematic shows a Horn Relay on trucks with Cruise Control only.
Without Cruise, 12v goes from fuse 8 to clockspring horn contacts, to horns.
With Cruise, it shows the horn relay location as under the left center of the dash, just about above the gas pedal area, very close to the Warning Chime Module, which is closer to the right center of the trans hump. It'll be the ONLY relay under there, directly connected to a socket/pigtail. Its wiring pigtail and the Chime pigtail both break out of the bigger harness next to each other.
