horn fuse
beachbumtroy
crystal river,fl.
ok as u kno i just got my 1998 ranger xtend cab,2 door, flareside, my horn was working quit the other day, i checked the relays by swapping relays with a friends truck nothing.............. then since i dont have a manual i went online and printed
a copy of fusebox inside and under hood.... the fusebox inside showed NO FUSE for a horn? the fusebox under hood show 2 relays 7 & 10 for horn but no fuse there ethier? is this right, no fuse for horn? and why does it show 2 relays for horn?
thnx for any help in advance, if there is no fuse then ill pull battery out to get to horn and appy power to it to see if it worx that way.
I don’t have my manual where I can look it but I seem the remember the fuse for the horn being in the cab. I might be mixing manufacturers as well. I’m thinking the fuse would be marked Hazard/Horn.
well my fuse cover inside the truck doesnt list fuses just numbers of each fuse, but the list i got off line didnt show any of the fuses being for a horn? i pulled each fuse and checked to see if ANY were
blown and they werent. heres a link to show what eachfuse does? and no horn that i can see?
