- Nov 4, 2007
- Manual
I'm not sure what your crankshaft pulley looks like, but mine only has one big bolt in the middle. If your problem is that the truck lurches when you try to loosen it...by filling one of the combustion chambers with rope you'll restrict the cranshaft's ability to rotate allowing you to get a good pull on your ratchet/breaker bar without the truck moving on you. The only pulley that I see with four bolts is the water pump pulley. Am I mis interpreting?
