- Mar 26, 2018
- Brighton, CO
- 3.0 V6
- Automatic
- My credo
- Friend of Bill W.
I want to add hood gas struts to my 2002 Ranger. Any recommendations for sources to buy?
Dunno about the newer Rangers but the older ones have hinges welded to the firewall... so the swap is kinda involved.
I have a set off an explorer in the barn but I havent been that hard up enough for entertainment to open that can of worms yet.
The strut ones bolt to the fender and the hood and don't involve messing with the hinges. I imagine the old coil spring design that can be found in older vehicles would probably have much more longevity but like you mentioned, way more involved to install.
Factory 95+ Explorers have the strut on the hinge and bolt to the firewall. Very clean looking.
Never really thought about it before but I don't know if/when the Ranger went to bolt on hinges. If they did it would be a fairly easy swap.
The explorer struts are doable, but I don't think it's exactly a bolt in swap. Like sgtsandman and 85_Ranger4x4 both said, I haven't paid close enough attemtion to my hinges to see how they are attached tot he firewall. That said my brain is screaming that it isn't a simple bolt on. Maybe a simple bolt off from the Explorer, but not that easy attaching to the Ranger. Ofcourse the idea when I had looked into it previously was to do it on a first gen Ranger.
I was going to recommend Reline like sgtsandman did. If I do struts on a first gen that's the route I've taking. Probably on the 99 as well, but this thread has me wanting to take a closer look at its firewall. I wonder if they would be strong enough to support the heavier fiberglass Edge hood.
where did you get that bumperThe OP has a 2002 so the he has bolted in hinges. I currently have 2 rangers with this hinge swap. It 'bolts' on, but the explorer hinges have a wider bolt pattern. So you have drill new holes, I just crimped nut-serts into the firewall and bolted the hinges right on.
In my 2000 I had to user 2 DRIVER side Explorer Hinges, and on my 2006 (which has the newer hood/grille style I had to use one each of LEFT AND RIGHT from the Explorer to line up with the hood. The firewall locations seemed to be identical so I guess the 04+ hood has different bolt spacing than the prior years). The hood also opens higher than it did with the prop rod now.
Hinges at my junkyard are $5ea and new Monroe gas struts are $7ea (as of Amazon's current price right now), I doubt any aftermarket strut add-on kit is cheaper than a $25 solution that is OEM fit and function..
Here is the 2000
