Homemade snorkel
I used exhaust tubing. Its durable, thin walled so it fits anywhere, comes in every size imaginable, durable, can be cut, bent, welded into any shape desired, annnd its cheap
Sent from my DROID RAZR using Tapatalk 2
I used heavy duty exhaust rated hose for mine
Been that way for 7 or so years.
perfect:icon_thumby:
This is sarcasm btw, anybody whos anybody around here put their snorkel in the cab with them they think theyre so cool, check this out my snorkels not on the outside like the other rednecks but in the inside mama! Although i personally think its a great idea hell make cold starts a helluva lot easier dont need to get out to spray the starting fluid in.......
And my luck it would back fire and stuck all the air from the cab.
Sent from my rooted SPH-D710 using Tapatalk 2
Glove box snorkels are pretty common. Most ppl aren't too wild about in cab diff/trans vents though.
I like to completely seal the inside of my cab so that's its like a little floating bubble then crack open the self contained oxygen tanks and giggle gas. If you water proof your wiring you could drive across a river just don't light up.
I wouldn't mind running it under the can to come up the rear through the bed. If it was sealed will enough and run through the frame then I don't see the issue. I saw the guys on the powerblock run it that way acc stick it in the toolbox for a turbo in a truck I think. They just cut a few holes on the underside for venting. That would keep it dry in a rainy situation too.
