vDawG
Here's my idea. If you have any input or a better idea let me know. I want to make rear leaf spring perches and at the same time bring the rear up 8" or so to match the front. If I start with 3" by 10" tube, cut the proper size hole for the axle tube in 2" deep in the tube (its and 8.8 so the hole diameter is 3.25"), drill out the center pin. Also I want to make them 7" long to eliminate the axle wrap that these things are bound to create. This seems easier and more sturdy then a block and shackle combo. What do you think???
