Daedalus
- Mar 23, 2010
Today I changed my oil for the second time since I bought my ranger in February. The oil was changed by my dads shop the day i bought it and I did my first oil change just under 3000 miles later. The oil that came out then didn't raise any alarms. I filled it up with Napa oil and used a Napa filter that I got as part of a $6 oil change 1 day promotion. Today when I changed it (2900 miles since last change, i always do mine early. i just get excited about a chance to give my vehicles some TLC i guess...) I noticed this in the bottom of the pan i used to drain the oil into after i dumped it into the bucket I was using to take it to be disposed of
I was a little worried but it was a small amount of rather small particles and there were no metal shavings in it. So no big deal right? Wrong.
When I dumped the bucket into the oil tank at the parts store I was horrified but what I saw in the bottom
There was an incredible amount of sludge in the bottom of the bucket. Huge friggin globs that nearly covered the bottom of a 5-gallon bucket. Still no metal shavings thankfully (checked with a magnet and by rubbing the sludge between my fingers).
Also when I removed the oil filter i noticed that the insides seemed to have become detached from the housing. When I'd tilt it one way I could feel and hear the internals move and bang against the side of the housing and then flop back and hit the other side when I tipped it the other way. From what I can tell the internals are intact, just disconnected from the housing. I couldn't see/hear multiple pieces moving in there. This was a standard napa filter, not a Napa Gold so I don't believe it is a Wix.
I've been noticing latley that my oil pressure gauge jumps around from normal to zero alot. When I first start it and drive for the first couple miles the pressure reads as fine, but after awhile it drops into the red. Then it will come back a few minutes later. I figured this was just a sensor issue since its so old and running fine. Now I'm guessing the sludge is blocking the screen but its being cleared after a few minutes slowing the pump to resume normal pressure.
So I filled it up with Castrol Semi-Synthetic (It was on sale, 19.99 for 5 quarts and a PureOne filter...) and put on a Pureolator PureOne oil filter. The oil pressure held steady at the normal place it rests when its not in the red and everything was great... For about 50 miles... Now its doing the back and forth thing again.
So it looks like the PO was an ass and didn't change the oil when he should have. So now its time to desludge the engine. I have three ideas on how to do this, each with their own risks and benefits.
1. Do it the slow and steady way. Change the filter in 500 miles, refill the lost oil from changing the filter and go another 500 miles before changing the oil (along with the filter again) entirely. At that time I'd probably go to a full synthetic for the adding cleaning properties. This may be safest as it has the lowest risk of throwing a huge chunk of crap into the pick-up tube screen and clogging up the works. Downside is judging by the oil pressure gauge fluctuations this is already happening intermittently. So If I do this i also risk slow and steady engine damage as the top end of the motor goes without oil at short but frequent intervals.
2. Dump in half a can of seafoam, drive for 50-100 miles and change the oil and filter. Run it for about 20 minutes and then change them again, effectively rinsing the engine after the cleaning In my experience this will clean ALOT of crap out very quickly but then im running the risk of throwing a chunk of sludge so big that the oil pump wont be able to clear it on its own after a few miles like its doing now. If this happens I'm up shit creek. With the condition the body is in it isn't likley to be worth it to remove the engine so I can drop the pan and replace or clean up the pump. Not to mention I don't have the resources to pay someone to pull the engine in the first place.
3. This seems to be the middle ground between the two. Drain a quart of oil out of the engine and replace it with ATF. Run it like this for up to 500 miles frequently checking the dipstick and changing the oil as soon as it looks bad. Repeat this process until I'm satisfied with the color/lack of chunks in oil that comes out.
I suppose there's also the old diesel fuel/kerosene in the oil technique also but this is an extreme move and will be an absolute last resort after everything else has failed, if I have the guts to try it all...
Well guys, what should I do?
